CrosbyFamilyFarm
#1 Posted : Thursday, December 31, 2015 1:28:32 PM(UTC)
CrosbyFamilyFarm
My washer had started making rattling noises and not draining, so I figured the impeller had gone or there was something stuck in the pump. I got a SUD error once and a F2 error (SUD happened this morning, F2 was from memory, i could be wrong).
I took the pump off and the impeller is worn through, rattling loose and not clicking as I would expect. Does anyone sell just the pump motor/impeller part that I'm looking for or am I stuck buying the whole pump assembly for $140?
Thanks!
sidfink43
#2 Posted : Thursday, December 31, 2015 2:49:04 PM(UTC)
sidfink43
I think you have to buy the whole assembly, sorry but that's the way Whirlpool does business. If you have a local repair shop they may be able to sell you a pump out of a scrap machine for just a few bucks. You can then either just replace parts or replace the whole pump, your choice.
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
Whirlpool Duet Washer - Wire broken off connector on harness (Washer Repair)
by Cephalon 1/21/2021 9:33:49 PM(UTC)
Whirlpool Duet Washer Codes (Washer Repair)
by mbocon 3/10/2020 5:04:51 PM(UTC)
Whirlpool duet washer (Dishwasher Repair)
by Julia Johnson 11/1/2017 9:53:41 AM(UTC)
What happened to my Whirlpool Duet washer?? (Washer Repair)
by colbran 10/2/2017 12:01:48 PM(UTC)
Whirlpool Duet Washer (Washer Repair)
by Bmbrouillette 7/2/2017 11:05:32 AM(UTC)
Whirlpool duet washer- won't start after replacing CCU and door latch (Washer Repair)
by Ivanick 5/22/2017 6:07:41 PM(UTC)
Whirlpool Duet washer FH code (Washer Repair)
by farmgirl 1/17/2017 7:14:25 PM(UTC)
whirlpool duet washer F06 E02 error (Washer Repair)
by tnafranklin 10/18/2016 12:47:55 PM(UTC)
whirlpool duet washer (Washer Repair)
by Oathose 4/4/2016 7:23:01 PM(UTC)
Whirlpool Duet Washer bellow tore in two. (Washer Repair)
by pitwoman 1/28/2016 5:42:42 PM(UTC)
Whirlpool Duet Washer not working (Washer Repair)
by Shanej69 11/23/2015 1:59:18 PM(UTC)
Whirlpool Duet washer start button is broken (Washer Repair)
by bjgamble 9/7/2015 7:04:46 AM(UTC)
