dlduchon
#1 Posted : Sunday, December 20, 2015 6:36:00 AM(UTC)
dlduchon
My Kitchen Aid Selectra 24 oven started shutting off when used for a long period of time. Now it shuts off if used for 45 minutes. It always resets and is ready to be turned on again afterwards but if I am not watching it my food does not get cooked. Recently it shut off and would only turn back on for a few minutes before shutting down and resetting. There is no error code and the control panel is working fine. Should I replace the thermoprotector? Rebuild the circuit board? Other ideas? Over work well otherwise.
#2 Posted : Sunday, December 20, 2015 8:07:51 AM(UTC)
Parts for KitchenAid KEBI141YBL0 Oven - AppliancePartsPros.com
See the attachment for a tech sheet. It is for a BL4 unit but is the only one I could find. Probably the same or very close to yours.
[COLOR="Blue"]Should I replace the thermoprotector?[/COLOR]
I do not see one in this unit.
[COLOR="Blue"]Rebuild the circuit board?[/COLOR]
The board is what I think is causing the problem.
Since the4 board is no longer available;le this is the only choice you have.
I do not know how successful repairing it would be as it takes 45 minites for the fault to happen.
dlduchon
#3 Posted : Monday, December 21, 2015 5:39:30 AM(UTC)
dlduchon
The thermoprotector is Part Number: AP3095457
Made by: Whirlpool Item # 20 on the diagram you attached. Is the thermoprotector a one time fuse or does it reset?
#4 Posted : Monday, December 21, 2015 6:05:39 AM(UTC)
I am not sure if it is a fuse or self-resetting.
But you had said the control panel works fine and I would say that this thermostat would kill power to the control board/panel so is not the culprit.
It would still be a good idea to check it with a meter should be 0 ohms at room temperature.
dlduchon
#5 Posted : Monday, December 21, 2015 8:44:52 AM(UTC)
dlduchon
When it trips when it gets hot the oven shuts off the control panel goes off and then resets and comes back on with the oven off.
