JamieLeighT
#1 Posted : Sunday, December 13, 2015 10:38:17 AM(UTC)
JamieLeighT
We are doing floor repair and had to move the stove last night. Woke up this morning to make breakfast and the oven light won't come on nor will it heat up. Also the stove top will not heat up BUT the stove indicator light turns on. I'm confused and hungry please help! :rolleyes:
JamieLeighT
#2 Posted : Sunday, December 13, 2015 10:46:58 AM(UTC)
JamieLeighT
Also as my 15 year old asked "Yes it is plugged in." Lol
#3 Posted : Monday, December 14, 2015 2:33:39 AM(UTC)
You seem to be missing several digits at the end of the model number.
Please check it.
First check power to the unit.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Do this with an element off and on.
