We are doing floor repair and had to move the stove last night. Woke up this morning to make breakfast and the oven light won't come on nor will it heat up. Also the stove top will not heat up BUT the stove indicator light turns on. I'm confused and hungry please help! :rolleyes:
Also as my 15 year old asked "Yes it is plugged in." Lol
You seem to be missing several digits at the end of the model number. Please check it.
First check power to the unit.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the wall receptacle L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with an element off and on. [COLOR="Red"]Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
