jmatters
#1 Posted : Tuesday, November 24, 2015 7:23:04 AM(UTC)
jmatters
My Maytag Gemini electric oven features a double oven. The upper oven works fine, but the lower oven won't heat. The broiler element is hot, but the bake element is cool. I tested the bake element and it reads 22 ohms. I tested the oven heat sensor and it read approximately 1,000 ohms at room temperature. When I wrapped my hand around the element, the resistance rose.
As it tries to heat up, the relay clicks on, then off again within a second or 2. I tested voltage going to the heating element in pre-heat mode. Approximately 25 volts. Then the relay clicked and the voltage rose to approximately 40 volts.
Thanks in advance for your help!
#2 Posted : Wednesday, November 25, 2015 2:14:29 AM(UTC)
Parts for Maytag MER6870AAC Range - AppliancePartsPros.com
Since the oven sensor and the bake element check out OK, odds are that the control board/timer is bad.
I would unplug the unit and check the wiring from the element back up to to the control board just to be sure it is also OK.
