donnajp
#1 Posted : Monday, November 9, 2015 7:18:05 PM(UTC)
donnajp
I have a Whirlpool Accubake with solid top. My right front dual burner will not adjust heat. It is continuously hot, even if I put it to the almost off position. Hope you can help me.
#2 Posted : Tuesday, November 10, 2015 12:47:08 AM(UTC)
Parts for WFE366LVT - AppliancePartsPros.com
You seem to be missing the last digit in the model number so youwill have to look in the Matching Model Numbers section.
I would replace the infinite switch, item 4 in section 01.
Be sure to tell them what element it is for as there are two different switches dependent on the element.
donnajp
#3 Posted : Tuesday, November 10, 2015 10:10:11 PM(UTC)
donnajp
Originally Posted by: denman Go to Quoted Post
Thanks so much. I will give it a try. It is bisque, so I think there should be a 1 after the LVT. Where do I find the type of element?
#4 Posted : Wednesday, November 11, 2015 12:48:18 AM(UTC)
Just tell them it is for a right front dual burner and they will know.
