I have a Whirlpool Accubake with solid top. My right front dual burner will not adjust heat. It is continuously hot, even if I put it to the almost off position. Hope you can help me.
Here are your parts Parts for WFE366LVT - AppliancePartsPros.comYou seem to be missing the last digit in the model number so youwill have to look in the Matching Model Numbers section. I would replace the infinite switch, item 4 in section 01. Be sure to tell them what element it is for as there are two different switches dependent on the element. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Here are your parts Parts for WFE366LVT - AppliancePartsPros.comYou seem to be missing the last digit in the model number so youwill have to look in the Matching Model Numbers section. I would replace the infinite switch, item 4 in section 01. Be sure to tell them what element it is for as there are two different switches dependent on the element. Thanks so much. I will give it a try. It is bisque, so I think there should be a 1 after the LVT. Where do I find the type of element?
Just tell them it is for a right front dual burner and they will know. |
