diyindux
#1 Posted : Thursday, November 5, 2015 4:39:33 AM(UTC)
diyindux
I'm having a problem with food particles being re-deposited on the dishes. Last year, a glass broke in the dishwasher and the pieces broke the impeller. I replaced the impeller and it worked well for a while but now I'm getting little chunks of food baked on to the dishes and glasses. I checked the impeller, volute and motor and all look good. The water level is just above the heating element after it fills, the check valve is clear and looks to be intact, all the dishes top and bottom are getting soaked during the wash cycle, the soap door opens, and the machine drains fine. The dishes just seem to be getting fully rinsed before the drying cycle. Glasses that go in clean on the outside come out with little pieces of food stuck on them. I'm at a loss. Some people have suggested that I need a new pump but with it spraying the water just fine I don't think that's it. I don't want to throw parts at it blindly. Any ideas what could be happening?
diyindux
#2 Posted : Monday, November 9, 2015 4:23:05 PM(UTC)
diyindux
Looks like I figured it out. I ran the diagnostic and it reset the OWI so now the machine can detect when the water is filthy and needs to be pumped out and replaced with clean water. Just follow the directions on the service sheet behind the toe kick.
