The ice maker works only after I manually raise arm and return back down. Is their some type of retrurn spring? I don't feel like it is returning enough to trigger switch to dump and call for water. It works fine for a couple cycles then I have to raise and lower arm to start the cycle again. Thanks for any advice.
THIS FORUM IS DEAD!!!!!!! |
Thank you, I took it out and put little oil on the moving parts. Thought I would try that first, I was thinking all along about adding some weight but wasn't sure about what kind or how. Hopefully won't need too, I will update in a few days. Thanks for the help!
