GEHELPWD
#1 Posted : Friday, October 30, 2015 11:28:08 AM(UTC)
GEHELPWD
My GE Dryer will start beeping in the middle of the night or day when not in use. Also when it is in use the only setting that I can use without it shutting off mid cycle is the Towel setting. What can be done? Which parts should I change out?
GEHELPWD
#2 Posted : Monday, November 2, 2015 10:04:27 AM(UTC)
GEHELPWD
Any input? Ran diagnostic test and got error code 68. after running diagnostic test over the weekend, no beeping but I am afraid this might be a temporary fix.
Any suggestions to what can be causing the problem?
