AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
GE Dryer will start beeping in the middle of the night
My GE Dryer will start beeping in the middle of the night or day when not in use. Also when it is in use the only setting that I can use without it shutting off mid cycle is the Towel setting. What can be done? Which parts should I change out?
Any input? Ran diagnostic test and got error code 68. after running diagnostic test over the weekend, no beeping but I am afraid this might be a temporary fix. Any suggestions to what can be causing the problem?
Dryer Repair
