jim-ma
#1 Posted : Sunday, October 18, 2015 8:05:45 AM(UTC)
jim-ma
Roper dryer only heats up on the 30 minute setting. The 60- 90 minute just puts out air. Suggestions?
#2 Posted : Wednesday, October 21, 2015 2:35:42 AM(UTC)
I cannot find any info on the given model number.
Please check it.
Find your model number - AppliancePartsPros.com
Could be a timer problem but you need to get a wiring diagram to be able to check this.
jim-ma
#3 Posted : Saturday, October 31, 2015 7:21:55 AM(UTC)
jim-ma
Please check it.
The ROPER dryer model# is RED4440VQ1
ser# M00514067
sometimes it will partially dry on the hi heat 30 min setting, no other settings will heat, they just blow out air.
#4 Posted : Saturday, October 31, 2015 11:52:44 AM(UTC)
Parts for Roper RED4440VQ1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Set the timer to a position that you know does not heat.
Unplug the unit.
Check that from A to B on the timer.
It should be 0 ohms.
Use your most sensitive meter scale.
jim-ma
#5 Posted : Wednesday, November 4, 2015 7:50:22 AM(UTC)
jim-ma
I will check it out this weekend and post the results, thanks!
