bluefitness
#1 Posted : Friday, October 30, 2015 10:25:48 AM(UTC)
bluefitness
Model number: 106.53206202
I've tried everywhere to get the service/technical manual for this unit to no avail. Kenmore and whirlpool could not provide it.
The refrigerator is not cooling, but the freezer is fine. The motorized air damper that feeds to refrigerator was in the closed position. I want to diagnose it instead of just guessing. There are 3 wires going to the damper.
orange/black
black
yellow/red
I'm getting 93v between orange/black and black
I'm getting 23v from y/r to b
I tried pushing on the damper manually. It is very hard to open.
Can someone provide a wiring diagram or let me know what reading (and purpose) of the 3 wires?
Thank you
bluefitness
#2 Posted : Friday, October 30, 2015 11:20:31 AM(UTC)
bluefitness
I figured out online how to run it in diagnostic mode. I held down the on/off button and filter button. I then pressed the filter button until step 5. I then received 120v to the air diffuser. It was still closed however. I could feel the diffuser vibrating.
I then ran it in normal mode and 120v was being sent to the diffuser. My diagnoses leads me to believe it is the air diffuser. I checked both thermistors and they were at 2.3k ohms (I had them in the same air temp.
What are your thoughts?
#3 Posted : Friday, October 30, 2015 11:21:46 AM(UTC)
See the attachment for the tech sheet
themarlars
#4 Posted : Saturday, October 31, 2015 12:08:26 PM(UTC)
themarlars
For Future Users with the same question: The wiring diagram should be on the back of the fridge in a bag, underneath in a bag, or under the compressor/coil/fan cover somewhere in there either in a holder or a bag.
bluefitness
#5 Posted : Monday, November 2, 2015 8:19:57 AM(UTC)
bluefitness
Thanks Denman for the wiring diagram.
Do you know the sequence of operation for these dampers? Are they normally closed and then open with power?
#6 Posted : Monday, November 2, 2015 9:22:23 AM(UTC)
Sorry but I do not know.
Guest (4)
