How do I remove agitator from this washer? I have removes the agitator cap from stud, but agitator seems to be stuck and will not pull off stud.
Your model number is missing a digit, but if this is a basic Whirlpool made machine then once you remove the 7/16" bolt from the agitator it should lift out.
If you have a lot of 'gunk' built up it make take an extra effort, or may need you to fasten some rope around it to get more leverage. But be careful, it can release suddenly and smack you in the face.
Thank you for your response. The washer is a Kenmore Model 110.7205614. There is no 7/16" bolt. Agitator is just sitting on a threaded stud. I think it should just pull off but that baby is like super stuck.
You left out one digit in the model number. If you will post that lets see what this looks like.
Went down and looked at the washer. Metal plate on back says: 110.7204614W
See if you can check again. There are usually no letters and 8 digits following the 110. on a Whirlpool made washer for Kenmore.
Groups: Expert
The ones without the bolt usually have a plastic insert that takes a large square extension from a socket set to turn instead.
