m179406
#1 Posted : Friday, October 16, 2015 11:36:58 AM(UTC)
m179406
How do I remove agitator from this washer? I have removes the agitator cap from stud, but agitator seems to be stuck and will not pull off stud.
sidfink43
#2 Posted : Sunday, October 18, 2015 6:26:11 AM(UTC)
sidfink43
Your model number is missing a digit, but if this is a basic Whirlpool made machine then once you remove the 7/16" bolt from the agitator it should lift out.
If you have a lot of 'gunk' built up it make take an extra effort, or may need you to fasten some rope around it to get more leverage. But be careful, it can release suddenly and smack you in the face.
m179406
#3 Posted : Wednesday, October 21, 2015 4:40:17 PM(UTC)
m179406
Thank you for your response. The washer is a Kenmore Model 110.7205614. There is no 7/16" bolt. Agitator is just sitting on a threaded stud. I think it should just pull off but that baby is like super stuck.
sidfink43
#4 Posted : Wednesday, October 21, 2015 4:43:54 PM(UTC)
sidfink43
You left out one digit in the model number. If you will post that lets see what this looks like.
m179406
#5 Posted : Wednesday, October 21, 2015 4:54:33 PM(UTC)
m179406
Went down and looked at the washer. Metal plate on back says: 110.7204614W
sidfink43
#6 Posted : Thursday, October 22, 2015 2:37:20 PM(UTC)
sidfink43
See if you can check again. There are usually no letters and 8 digits following the 110. on a Whirlpool made washer for Kenmore.
bizkid23
#7 Posted : Friday, October 23, 2015 6:18:07 AM(UTC)
bizkid23
Groups: Expert
The ones without the bolt usually have a plastic insert that takes a large square extension from a socket set to turn instead.
Guest (4)
Whirlpool Ultimate Care II, how do u remove Agitator Cam? (Washer Repair)
by DieselDavy 4/18/2020 5:07:51 AM(UTC)
Remove agitator - no lint being pumped ou (Washer Repair)
by ccumbow 10/14/2015 6:24:47 AM(UTC)
How to remove agitator on GE GTWP1800D0WW (Washer Repair)
by CCC1620 1/24/2015 10:40:44 AM(UTC)
How to remove agitator from GE washer (Washer Repair)
by jthrrt 1/1/2013 4:43:23 PM(UTC)
How to remove agitator (Washer Repair)
by just_chillin38 12/27/2012 12:12:34 PM(UTC)
How to Remove Agitator (Washer Repair)
by this_is_nascar 6/11/2012 8:32:07 AM(UTC)
by 1ottar 11/9/2011 11:44:54 AM(UTC)
how to remove Agitator on Frigidaire (Washer Repair)
by vinster 10/4/2011 11:46:19 AM(UTC)
by yooperman 7/8/2011 5:31:25 PM(UTC)
Remove agitator (Washer Repair)
by NannyBeck 5/19/2011 4:22:38 PM(UTC)
Remove Agitator - How? (Washer Repair)
by amana user 7/10/2010 9:56:14 AM(UTC)
by surgonfish 3/27/2010 6:58:12 AM(UTC)
How to remove agitator assembly (Washer Repair)
by BylerB 3/6/2010 5:41:41 AM(UTC)
how do i remove agitator (Washer Repair)
by hm7956 2/15/2010 11:47:23 AM(UTC)
by Larry225 2/9/2010 5:11:24 PM(UTC)
