2 Pages12>
GreggyG
#1 Posted : Friday, October 9, 2015 7:53:30 PM(UTC)
GreggyG
I had an issue with this unit not drying and leaving clothes wet, no codes though. I replaced the thermistor and the other part next to it. The unit ran fine for one cycle then left clothes wet on the second cycle, then shows the f25 code. I cleaned all the vents just in case and the lint from the fan blades. Code is still reading but I can feel the heat when I open the door after running for less than one minute. Is there a way to simply reset the code? Why is it still showing it? Thank you!!!
#2 Posted : Saturday, October 10, 2015 1:47:20 AM(UTC)
A model number would be helpful.
Find your model number - AppliancePartsPros.com
GreggyG
#3 Posted : Saturday, October 10, 2015 5:16:59 AM(UTC)
GreggyG
WED9200SQ0 thank you!!!
#4 Posted : Saturday, October 10, 2015 7:22:51 AM(UTC)
If it keeps recurring then unplug the thermistor at the control board.
Then if it shows up again I would say there is a problem with the board.
GreggyG
#5 Posted : Sunday, October 11, 2015 8:46:32 PM(UTC)
GreggyG
Is it possible that it's just a stored code in memory?
#6 Posted : Monday, October 12, 2015 1:03:19 AM(UTC)
Yes it is possible that it is just a stored code.
GreggyG
#7 Posted : Wednesday, October 14, 2015 5:46:37 AM(UTC)
GreggyG
After a couple of loads, the f25 code is still there and they clothes are coming out damp. Any other ideas or guidance?
#8 Posted : Thursday, October 15, 2015 6:49:28 AM(UTC)
Since you have tried to clear it and it keeps recurring and if you have tried the troubleshooting on Page 7 of the tech sheet I would say that the problem is on the board.
GreggyG
#9 Posted : Wednesday, October 21, 2015 5:32:55 PM(UTC)
GreggyG
I replaced the board, instantly got an F01 and an F28 as soon as I powered up. Reset the unit and codes are cleared. But, I still have the problem of the heavy duty light not illuminating when in diagnostic mode. I haven't dried any clothes yet but I think there is a problem because the instructions say that all lights should illuminat. I checked the moisture sensor by putting it in diagnostic mode an opening the door. I get P3E and a single beep. When I bridging the sensor strips, I get a constant beep and 2:00. Is there still a problem?
GreggyG
#10 Posted : Wednesday, October 21, 2015 6:41:36 PM(UTC)
GreggyG
And now this just happened. it just started beeping while it was drying, but no codes. Could it be the user interface panel? I'm so lost and distraught.
2 Pages12>
