2 Pages12>
GreggyG
#1 Posted : Friday, October 9, 2015 7:53:30 PM(UTC)
GreggyG
I had an issue with this unit not drying and leaving clothes wet, no codes though. I replaced the thermistor and the other part next to it. The unit ran fine for one cycle then left clothes wet on the second cycle, then shows the f25 code. I cleaned all the vents just in case and the lint from the fan blades. Code is still reading but I can feel the heat when I open the door after running for less than one minute. Is there a way to simply reset the code? Why is it still showing it? Thank you!!!
#2 Posted : Saturday, October 10, 2015 1:47:20 AM(UTC)
A model number would be helpful.
Find your model number - AppliancePartsPros.com
GreggyG
#3 Posted : Saturday, October 10, 2015 5:16:59 AM(UTC)
GreggyG
WED9200SQ0 thank you!!!
#4 Posted : Saturday, October 10, 2015 7:22:51 AM(UTC)
If it keeps recurring then unplug the thermistor at the control board.
Then if it shows up again I would say there is a problem with the board.
GreggyG
#5 Posted : Sunday, October 11, 2015 8:46:32 PM(UTC)
GreggyG
Is it possible that it's just a stored code in memory?
#6 Posted : Monday, October 12, 2015 1:03:19 AM(UTC)
Yes it is possible that it is just a stored code.
GreggyG
#7 Posted : Wednesday, October 14, 2015 5:46:37 AM(UTC)
GreggyG
After a couple of loads, the f25 code is still there and they clothes are coming out damp. Any other ideas or guidance?
#8 Posted : Thursday, October 15, 2015 6:49:28 AM(UTC)
Since you have tried to clear it and it keeps recurring and if you have tried the troubleshooting on Page 7 of the tech sheet I would say that the problem is on the board.
GreggyG
#9 Posted : Wednesday, October 21, 2015 5:32:55 PM(UTC)
GreggyG
I replaced the board, instantly got an F01 and an F28 as soon as I powered up. Reset the unit and codes are cleared. But, I still have the problem of the heavy duty light not illuminating when in diagnostic mode. I haven't dried any clothes yet but I think there is a problem because the instructions say that all lights should illuminat. I checked the moisture sensor by putting it in diagnostic mode an opening the door. I get P3E and a single beep. When I bridging the sensor strips, I get a constant beep and 2:00. Is there still a problem?
GreggyG
#10 Posted : Wednesday, October 21, 2015 6:41:36 PM(UTC)
GreggyG
And now this just happened. it just started beeping while it was drying, but no codes. Could it be the user interface panel? I'm so lost and distraught.
Guest (9)
2 Pages12>
