Hi everyone, my kitchenaid dw's rinse aid is not working. I took the door panel off to observe the dispenser and found the wax motor for the dispenser will not retract back to normal state. I am leaning toward the problem is with the control board. Is there anything else that controls the dispenser? What do you think?
Here are your parts Parts for KitchenAid KUDC10FXSS5 / - AppliancePartsPros.comSee the attachment for the tech sheet. The dispenser is controlled directly from the control board. I am assuming that it does retract properly when you remove power to it. It would not hurt to check it for resistance. If OK then replace the board. |
THIS FORUM IS DEAD!!!!!!! |
Thanks Denman. Yes Iyou are correct. The motor does retract after the dishwasher has completed.
