Cappy11078
#1 Posted : Tuesday, October 13, 2015 6:36:57 PM(UTC)
Cappy11078
Hi everyone, my kitchenaid dw's rinse aid is not working. I took the door panel off to observe the dispenser and found the wax motor for the dispenser will not retract back to normal state. I am leaning toward the problem is with the control board. Is there anything else that controls the dispenser? What do you think?
#2 Posted : Wednesday, October 14, 2015 2:53:58 AM(UTC)
Parts for KitchenAid KUDC10FXSS5 / - AppliancePartsPros.com
The dispenser is controlled directly from the control board.
I am assuming that it does retract properly when you remove power to it.
It would not hurt to check it for resistance.
If OK then replace the board.
Cappy11078
#3 Posted : Wednesday, October 14, 2015 2:24:11 PM(UTC)
Cappy11078
Thanks Denman. Yes Iyou are correct. The motor does retract after the dishwasher has completed.
