Tia_burke
#1 Posted : Monday, October 12, 2015 5:19:00 PM(UTC)
Tia_burke
My dryer when on the setting panel lights up but when I hit the start button it makes a clicking sound like it wants to start, but won't
#2 Posted : Tuesday, October 13, 2015 2:56:53 AM(UTC)
Parts for Maytag MED4200BW0 / Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram
OOPS!! I messed this up and editing a post will not let me attach a file so please see my next post.
Try turning the drum in the correct direction just to be sure it is not seized up. It should turn fairly easily.
Check the belt. The unit has a belt switch so a broken belt will hold the motor off.
#3 Posted : Tuesday, October 13, 2015 2:59:53 AM(UTC)
Here is the attached wiring diagram.
