My dryer when on the setting panel lights up but when I hit the start button it makes a clicking sound like it wants to start, but won't
Here are your parts Parts for Maytag MED4200BW0 / Dryer - AppliancePartsPros.comSee the attachment for the wiring diagram OOPS!! I messed this up and editing a post will not let me attach a file so please see my next post. Try turning the drum in the correct direction just to be sure it is not seized up. It should turn fairly easily. Check the belt. The unit has a belt switch so a broken belt will hold the motor off. |
THIS FORUM IS DEAD!!!!!!! |
Here is the attached wiring diagram. |
