Pulled the thrust bearing. Looks good no worn spots on gear. Now I can't get the C clip back on because it does not engage slot in shaft. It must have been put on under pressure because I can't get it to engage slot.
Originally Posted by: sidfink43  Well now it does sound like the transmission, although I still think the timer is a possibility. If you want to try and change it out and order the timer from this site you can return it if it does not fix the problem. Pulled the thrust bearing. No visible signs of damage. Now I cannot get the c-ring back on shaft. With the washer on the slot is not able to accept the c-ring.??????????????
