johnhb
#1 Posted : Wednesday, September 30, 2015 7:27:45 AM(UTC)
johnhb
Dryer is overheating and shutting down after 15-20 minutes. If I wait a half hour it will restart and run for 10 minutes or so. The vent was badly clogged when this first happened but it's totally clean now. I'm an electrician so it seems like it might be some high limit switch is not working. I'm not familar with the machine and don't have a wiring diagram. I would really appreciate some help.
JB
#2 Posted : Wednesday, September 30, 2015 7:57:16 AM(UTC)
Parts for Kenmore Dryer 11066722694 - AppliancePartsPros.com
If you go to the Dears parts siteb there are part breakdown diagrams.
Unfortunately these are not available to other vendors.
It sounds like the motor is overheating.
This then trips it's internal thermal protect and shuts the unit down. You then have to wait for the motor to cool down before the unit will restart.
Try turning the drum in the correct direction. It should turn fairly easily if not perhaps the motor is overloaded. You may want to try this on a couple other units to get a feels for it.
If it is hard to turn then there is a problem with the drum mounting or the idler wheel etc.
Give the interior a good cleaning including the motor and the blower wheel.
Check tht the seal between the motor and the blower is OK. If not the blower may be blowing hot air back onto the motor.
Could also be that the motor is on it's last legs.
I cannot find a wiring diagram for this unit. I(t may be glued to the back of the dryer or in the control console.
johnhb
#3 Posted : Wednesday, September 30, 2015 8:41:19 AM(UTC)
johnhb
Thank you, I will be taking the dryer apart tomorrow and will check the motor, heating element, and 3 t-stats. I'll let you know how I make out.
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
Kenmore electric dryer won't stay running (Dryer Repair)
by steve37887 10/25/2019 4:52:25 AM(UTC)
Kenmore Electric dryer (Dryer Repair)
by scorpio012 1/21/2018 12:45:44 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Kenmore electric dryer (Dryer Repair)
by carpenter83 12/1/2016 3:23:22 PM(UTC)
Kenmore Electric Dryer (Dryer Repair)
by johnhb 9/30/2015 7:27:43 AM(UTC)
Kenmore Electric Dryer Won't power up. (Dryer Repair)
by lamarc72 11/19/2013 9:30:31 AM(UTC)
Kenmore Electric Dryer Runs and No Heat (Dryer Repair)
by dadunn1960 3/15/2013 8:14:52 AM(UTC)
Kenmore Electric Dryer - drum hits the top of the dryer. (Dryer Repair)
by willow5000 2/14/2013 9:19:06 PM(UTC)
Kenmore Electric Dryer - Runs but no heat and timer not running (Dryer Repair)
by CapN 12/11/2012 5:31:31 AM(UTC)
Kenmore Electric Dryer cuts off after running 2/3 minutes (Dryer Repair)
by Robert Ferrell 10/14/2011 9:21:09 AM(UTC)
Kenmore ELectric dryer (Dryer Repair)
by Donnadryer 9/11/2011 3:56:16 PM(UTC)
Kenmore electric dryer starts and stops (Dryer Repair)
by missfixit1974 9/9/2011 12:59:29 PM(UTC)
Kenmore electric Dryer won't Tumble (Dryer Repair)
by ohmydryer 9/6/2011 2:09:46 PM(UTC)
