Thanks For The Help
#1 Posted : Monday, September 21, 2015 4:12:29 PM(UTC)
Thanks For The Help
The defrost on my Whirlpool fridge (ET14NKXGW02) is not working (freezes up).
I have already confirmed that the defrost heater works.
I have located the timer, but am confused about locating the "bi-metal switch".
Is it the small silver and blue clip-on "button" on this wiring harness :
Whirlpool 2192096 Wiring, Freezer - AppliancePartsPros.com
If so, I put it in a sealed cup full of ice for over an hour and never got continuity across that "button". Am I on the right track ?
#2 Posted : Wednesday, September 23, 2015 1:17:13 AM(UTC)
Yes that is the defrost thermostat.
[COLOR="Blue"]Am I on the right track ?[/COLOR]
Yes as it should read 0 ohms when frozen
Thanks For The Help
#3 Posted : Thursday, October 1, 2015 2:46:13 PM(UTC)
Thanks For The Help
Thanks DenMan !
I "jumpered" that defrost thermostat, and the timer kicked on the heater (when it reached the "defrost cycle"). So now I've replaced the defrost thermostat and the whole thing works perfectly !
Thanks again.
#4 Posted : Friday, October 2, 2015 4:24:21 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
