Reba k
#1 Posted : Monday, September 7, 2015 1:33:51 PM(UTC)
Reba k
My Frigidaire refrigirator has been running constantly. The food is being kept cd at a safe level. I have tried moving it farther awAy from the wall and vacuuming. The kitchen is currently around 85 degrees since there is no AC. Is the heat related or is this a larger issue that requires a repair call?
CletusT
#2 Posted : Wednesday, September 9, 2015 8:04:01 PM(UTC)
CletusT
Most refrigerators like to run at 60 to 90 degrees before they misbehave or rebel. If the food is at a safe temperature, and it isn't freezing the food in the refrigerator section, then it may be heat related.
I would point a box fan in that direction and see what happens. If it is freezing food in the fresh food section, then the thermostat may be bad.
