My Frigidaire refrigirator has been running constantly. The food is being kept cd at a safe level. I have tried moving it farther awAy from the wall and vacuuming. The kitchen is currently around 85 degrees since there is no AC. Is the heat related or is this a larger issue that requires a repair call? Thanks
Most refrigerators like to run at 60 to 90 degrees before they misbehave or rebel. If the food is at a safe temperature, and it isn't freezing the food in the refrigerator section, then it may be heat related. I would point a box fan in that direction and see what happens. If it is freezing food in the fresh food section, then the thermostat may be bad.
