I changed the front outer tub (PN AP3773838) from my washer machine and there is a hole in the bottom front part where the washer temperature sensor is located. The hole is bigger in the new front outer tub and the seal do not cover properly the hole and it leaks. I order a new seal (PN 8181829) and a new temperature sensor (PN 8181705) but the seal is the same size as the old one and the leak still happens. I'm not sure if using a sealing will solve the problem because the seal has a lot of play in the hole.
