Dryer runs fine but heats intermittently works when you initially start it then stops heating. Let it cool down for an hour start it works again than stops heating. Any suggestions or testing procedures would be appreciated as well as possible parts and part numbers.
Have you had any luck with this issue? I have the same model and same symptoms. Thanks
Check the thermostat(s) and high limit switch for continuity.
