taz_monster
#1 Posted : 10 years ago
taz_monster
I,
I need Help!!!
Yesterday I have to replace my motor in my dishwasher, find the part, change it and splash a gain in the machine, So now I have an other problem, I dont have anay heat on the element,
I have 13 oms for the element, I test the wiring to the control box, ok.
This morning I have pull out again my dishwasher just for checking if everithing is pluged, all ok.
What I miss!!!
:eek:
#2 Posted : 10 years ago
Here are your parts'
An AYW3 does not come up so the parts are for an AYW2.
They are probably the same.
Parts for Whirlpool WDF750SAYW2 / Dishwasher - AppliancePartsPros.com
See the attachment for your tech sheet.
Did you check the hi-limit thermostat (item 25 in section 05).?
It should be 0 ohms.
Also it might be a good idea to check the heater circuit at the control board. P4-3 to P4-4. This will check the heater, the hi-limit and the wiring.
Also check the thermistor resistance, see the tech sheet.
taz_monster
#3 Posted : 10 years ago
taz_monster
thanks
Yes, I check them o ohms,
I check on close circuit, Item by item, The element is 13 ohms, the termal sensor is ok.
I think it is the relay. So it is weld on board.
Tahnks
#4 Posted : 10 years ago
Yes it is soldered to the board.
It may be a bad relay but also could be the electronics that control the relay
WTW500DW1 wirlpool washer (General Talk)
by Ashley5791 3 years ago
Wirlpool Centennial Washer (Washer Repair)
by 405husky 5 years ago
Wirlpool 6ED22PKFXW01 (Refrigerator & Freezer Repair)
by Ady_E 6 years ago
older Wirlpool dryer won't heat (Dryer Repair)
by automaticman 11 years ago
wirlpool microwave (Microwave Repair)
by CFP 11 years ago
wirlpool icemaker (Refrigerator & Freezer Repair)
by jimmy icemaker 12 years ago
Wirlpool dishwasher upper arm not spinning (Dishwasher Repair)
by mogul397 12 years ago
Wirlpool dishwasher will not stop cycling (Dishwasher Repair)
by dbarrett76 12 years ago
wirlpool topload agitates but won't spin or pump motor hums (Washer Repair)
by curly33333 13 years ago
Wirlpool Dishwasher Inlet Valve Voltage (Dishwasher Repair)
by nezoic 13 years ago
my wirlpool washer wont spin (Washer Repair)
by cockroach 14 years ago
Wirlpool Ultimate care II (Washer Repair)
by Peter R. 14 years ago
Wirlpool Micorwave blows fuse when I press start magnetron or transformer (Oven Repair (including Ranges and Cooktops))
by wetpinkpants 15 years ago
Need Wirlpool Mh3184xpy-1 tech sheet (Dishwasher Repair)
Wirlpool SM8280867 - Agitates but nothing else, won't drain (Washer Repair)
by clfry 15 years ago
