I just replaced my water inlet valve on my Admiral washer and got the white electric plug to the top for cold and the red to bottom for hot. My problem is that I didn't pay attention to where the 2 small wires go to, one is pink and the other is yellow with a red stripe. Would something bad happen if I accidently got those backwards? Or does it really matter? Your video shows pink going on the left so I need to know before using the washer again. I have water inlet valve part 3979346.
Groups: Expert
It doesn't matter which way they are connected.
Eric
