2 Pages12>
phantomracer
#1 Posted : 10 years ago
phantomracer
Bought a house with a kems307gbl0 microwave / oven combo.
initially, worked great. Now the microwave takes forever to heat anything.. 5-6 minutes for popcorn (was 2.x minutes before), heat a slice of pizza 2-3 minutes (was <1 minute).
Wasn't sure if this is a magnatron issue or something else.
Thanks for any help
Paul
Simon / APP Team
#2 Posted : 10 years ago
Simon / APP Team
Groups: APP Team
Hi, Paul.
You are absolutely right - it's got to be the magnetron:
Part number: AP4412010
Here are the breakdown diagrams and parts list for your microwave:
Model KEMS307GBL0
Good luck. Please keep us posted with the results.
Thank you,
Simon.
phantomracer
#3 Posted : 10 years ago
phantomracer
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi, Paul.
Model KEMS307GBL0
Thank you,
Simon.
Thanks. That was my initial go to guess... of course..reading everything online.. elsewhere, someone mentioned it might be a thermal cut off or bad thermostat or something over heating that just might need to be cleaned.. my spidey sense still leads me to the magnatron, where the unit is 15 years old.
Is there any tip or trick to getting to the mag in this particular model, short of just hunting and pecking til I find it?
Just wanted to be sure that it was most likely the magatron, before dropping $126 on the part.
Simon / APP Team
#4 Posted : 10 years ago
Simon / APP Team
Groups: APP Team
Hi, Paul.
First of all we have a return policy that allows you to return any parts you don't need for full refund within one year.
There is no any special trick to make your life easier :(. You will have to lift of the console, remove the top and bottom grills, remove two screws holding the unit at the bottom one on each side and then slide the unit out. Be careful with wires, disconnect them all after memorizing where they go (take a picture). Oh, and don't forget to turn the breakers off!!!
Good luck.
Thank you,
Simon.
phantomracer
#5 Posted : 10 years ago
phantomracer
Hi, Paul.
Good luck.
Thank you,
Simon.
Thanks once again...
So no problem returning a part that was installed that didn't fix the problem. I normally don't like randomly replacing parts, but as long as I can return it, that takes some of the pressure off.
Simon / APP Team
#6 Posted : 10 years ago
Simon / APP Team
Groups: APP Team
Give it a shot.
Thank you,
Simon.
phantomracer
#7 Posted : 9 years ago
phantomracer
Thanks. Got the magnetron installed. seemed to help a bit, but still seems to heat slowly..
if I make, say, popcorn, it takes about 4-5 minutes to get 1-2 pops a second, then half the bag is burnt, and half unpopped. If I use the popcorn button, about, or over, half the bag is unpopped.
The microwave 'hums' for about 15-30 seconds..then stops humming for about 10-15, then hums again (repeats) I assume the humming is the magnetron engaging.
Thoughts to something else being the problem? Any heat or safety sensor that could be failed or weak?
phantomracer
#8 Posted : 9 years ago
phantomracer
any idea on my post above?
Paul
phantomracer
#9 Posted : 9 years ago
phantomracer
some more info:
hums (cooking i assume) for 17-18 seconds, then no humming for 3 seconds... over and over
think it could be a bad replacement magnetron? or something else?
myappliancea
#10 Posted : 9 years ago
myappliancea
My microwave is doing the same thing or similar. It'll cook food but not pop popcorn. I also cant adjust the power setting.
I've rea it can be a bad triac. Have you tried that? I thinking ill test it out on mine to see if its bad.
2 Pages12>
