2 Pages<12
phantomracer
#11 Posted : Friday, November 6, 2015 5:49:02 PM(UTC)
phantomracer
I replaced the magnetron as i said above, which didn't seem to fix it, although did make it marginally better.
Since I didnt get a reply here, I chatted with them. They suggested I replace the high voltage transformer
I replaced it today, and it seems better. I haven't put it through its paces, but it works without the humming
phantomracer
#12 Posted : Thursday, March 17, 2016 5:15:19 AM(UTC)
phantomracer
Just an update. Hum came back. The transformer did not fix it. Basically replaced every part - still not working.
Finally replaced the control panel - got it off ********, NOS, as the unit has been discontinued for some time. There are companies that will repair the circuit board, but I did score one.
This seems to have fixed the problem. Apparently the relay on the circuit board was bad/wore out over the years
Been working great for the past few weeks, so I am 99% sure it is fixed.
Guest
#13 Posted : Tuesday, February 20, 2024 9:17:25 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Starting up slow
2 Pages<12
