I installed a new GE dishwasher this week. The connections were not leaking when water was turned on for the first trial. Ran the dishwasher through a complete cycle and noticed leak at connection from elbow to water valve. Tightened the connection and leak got worse. Decided that the plumbing parts store might have given me the incorrect elbow (NST instead of GHT). Went to a different plumbing parts store and purchased a GHT elbow. Installed it and it is leaking too around the plastic threads on the water valve part of the dishwasher. Could it be that the plastic threads have become cross threaded? Is there a solution to cross threading on plastic threads other than replacing the water valve? The appliance parts store said that they did not have the water valve in stock for this dishwasher and it would have to be ordered in from GE. In looking at the GE parts site, it appears that the water valve part number for my dishwasher is no longer available and has been replaced with a different part. There are no pictures of the new part...only the $51 price. I'm wondering if GE knew this was a poorly manufactured part and changed it. I also noticed a leak at the bottom right corner of the door after the first cycle. The GE parts site also noted that the door gasket for my dishwasher was no longer available and had been replaced by another part. Again, I'm wondering if GE knew this part was defective. I have a GE service tech scheduled to come out tomorrow (the earliest they were available). I don't want to have to pay to replace something that GE knows is a defective part. Any suggestions?
Here are the parts for the PGD0BB unit Parts for GE GDF520PGD0BB / Dishwasher - AppliancePartsPros.comBelow is the valve for a PGD0BB. The PGD6BB does not come up on AppliancePartsPros. Odds are high that they are the same. Double check this with a parts representative Click on the picture for more info on the part Part number: AP5669207
[COLOR="Blue"] Could it be that the plastic threads have become cross threaded?[/COLOR] Yes Is there a solution to cross threading on plastic threads other than replacing the water valve? Yes Sorry I do not know about the door gasket. You may have also overtightened the fitting and split the plastic. Note that the shown valve uses a brass coupling not plastic. Always a good idea when doing this type of connection to wrap a few turns of pipe tape around the threads before installing. |
THIS FORUM IS DEAD!!!!!!! |
