biged72752
#1 Posted : Monday, July 27, 2015 10:44:11 AM(UTC)
biged72752
heat is always on. no control. the timer works and have checked out the temp. control switch. act as if the thermostat won't shut off. have replaced the on at the top of the heater vent and the fuse. sometimes the timer will time down but not shut off
fairbank56
#2 Posted : Monday, July 27, 2015 12:21:38 PM(UTC)
fairbank56
Groups: Expert
Double check the model number, doesn't appear to be valid.
Eric
biged72752
#3 Posted : Friday, July 31, 2015 5:17:31 AM(UTC)
biged72752
double checked no. it is correct, type of dryer dwsr ele 2496028 fm54. hope this will help
fairbank56
#4 Posted : Friday, July 31, 2015 7:44:23 AM(UTC)
fairbank56
Groups: Expert
Model number does not come up at sears parts site. The 110 is a prefix and means it's made by Whirlpool, the next 5 numbers are the Sears part number. Last 3 is date code and version. Never seen a Sears part number start with a zero. Is this a Canadian model? You may have a grounded heat element but I need to see the tech sheet or wiring diagram and can't without a model number that works.
Eric
biged72752
#5 Posted : Friday, July 31, 2015 11:09:06 AM(UTC)
biged72752
double/double checked and the # is 110 627 121 00 . It is terrible to get old and blind. Just to let you know . have replaced the thermal switch in the top of the heater. the switch in the bottom in the exhaust checks ok the heater part is 6k but can't tell if the other part even works.
fairbank56
#6 Posted : Friday, July 31, 2015 1:44:17 PM(UTC)
fairbank56
Groups: Expert
I would check for a grounded heat element. If it produces heat even when set to air only, that's a sure sign of a grounded element.
Eric
Guest (4)
Kenmore Gas dryer, no heat control (Dryer Repair)
by iowacows 8/13/2013 4:18:50 PM(UTC)
