Hi, my dishwasher is having some issues. The water tower doesn't seem to come up and the water just froths out in a bubbly form. I replaced the water inlet valve and the water shutoff seems to work fine. I am just not sure what could be the problem at this point as the motor is working.
Groups: APP Team
Hi, Andrew.
Please double check and post the complete model number of your dishwasher. Also there are a couple of things I'd like to ask you: does water fills in so it's almost up to the heating element? Have you checked two filters under the lower wash arm? If those filters are clogged with calcium deposits the water pressure won't be enough to shoot up into the upper wash arms.
Thank you,
Simon.
