Does anyone know how to remove the assembly on the freezer door to replace the water lever? See attached pic of freezer door. treatcg attached the following image(s):
No clues. I have pulled and pulled and no luck. The trim ring that is flush is under the skin of the freezer door. I don't see anyway to remove the touch screen without getting this ring off first.
Figured it out finally. Since it is a stainless model the freezer door skin must be removed. Screws along top, bottom and hinge side.
