treatcg
#1 Posted : Sunday, July 12, 2015 8:52:37 AM(UTC)
treatcg
Does anyone know how to remove the assembly on the freezer door to replace the water lever? See attached pic of freezer door.
treatcg attached the following image(s):
treatcg
#2 Posted : Sunday, July 19, 2015 12:55:19 PM(UTC)
treatcg
No clues. I have pulled and pulled and no luck. The trim ring that is flush is under the skin of the freezer door. I don't see anyway to remove the touch screen without getting this ring off first.
Figured it out finally. Since it is a stainless model the freezer door skin must be removed. Screws along top, bottom and hinge side.
