SPPV
#1 Posted : Thursday, July 16, 2015 5:58:27 AM(UTC)
SPPV
Fridge and freezer both stay at around 18C. I removed the freezer panel, evaporator is running and not iced up. Removed the bottom back panel. Compressor was running but condenser fan wasnt. It was very dirty and a mouse was stuck in the fan. So I unplugged it, cleaned it and removed the mouse. Plugged it back in and fan spun right up. So I figured problem solved. Put a small dish of water in the freezer and thermometer in the freezer. 6 hours later water not even starting to freeze and fridge is still around 18C.
Its not going into defrost since anytime I open the freezer the evaporator is running and it shuts down when in defrost mode.
What else should I check or do?
Simon / APP Team
#2 Posted : Thursday, July 16, 2015 8:22:21 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please, make sure that compressor is running. It should make a bit of a humming sound and slightly vibrate. It also supposed to be really warm to a touch. If it runs I need you to remove the evaporator coil cover in the freezer again and check if a wet finger will stick to the coil surface all around the coil.
Please, let me know the results.
Thank you,
Simon.
SPPV
#3 Posted : Friday, July 17, 2015 4:34:16 PM(UTC)
SPPV
Compressor is running and I can feel the heat from a couple inches away. Ive opened up the freezer again, finger does not stick to the grill but some ice has formed over one of the wires/tubes
UserPostedImage
There was some peeling tape and gooey clay like stuff around a cylinder. I removed the ice (the tape and clay came with it) and have plugged the fridge back in and put a bowl of water in the freezer again to test
Simon / APP Team
#4 Posted : Friday, July 17, 2015 7:15:04 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
From what I see on the picture it's a sealed system problem. Most likely a restriction within the capillary tube. It's a job for a professional appliance tech with a proper equipment and experience.
Thank you,
Simon.
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
LG fridge not cooling - freezer and ice maker fine - doesn’t look to be defrost related either (Refrigerator & Freezer Repair)
by Guest 7/25/2022 6:04:54 PM(UTC)
Kenmore Elite Fridge Not Cooling or Defrosting (Refrigerator & Freezer Repair)
by ktd.ajd 8/15/2020 6:47:12 PM(UTC)
fridge not cooling good (Refrigerator & Freezer Repair)
by corvairbob 7/27/2020 2:46:12 PM(UTC)
33 year old GE fridge not cooling (Refrigerator & Freezer Repair)
by stevebass 7/11/2020 4:05:50 PM(UTC)
Fridge not cooling enough, but Freezer is fine (Refrigerator & Freezer Repair)
by corriganama 8/19/2019 10:48:58 AM(UTC)
LG LMXC23467D fridge not cooling (Refrigerator & Freezer Repair)
by trkinspector 7/26/2019 6:28:02 PM(UTC)
LG fridge LFC23760ST freezer not freezing, now fridge not cooling (Refrigerator & Freezer Repair)
by blairm 1/20/2019 1:40:44 AM(UTC)
Samsung RF263 Fridge Not Cooling (Refrigerator & Freezer Repair)
by Deke1 6/15/2018 4:05:20 PM(UTC)
Maytag French door fridge not cooling down (Refrigerator & Freezer Repair)
by Sworddylan 10/8/2017 6:50:20 PM(UTC)
Fridge not cooling, freezer is cold (Refrigerator & Freezer Repair)
by ashtong63 9/28/2017 7:22:18 PM(UTC)
by richardwilliamsfaia 4/30/2017 11:14:36 AM(UTC)
Fridge not cooling. No frost on coils. (Refrigerator & Freezer Repair)
by miketh2005 2/20/2017 3:24:09 PM(UTC)
Haier fridge not cooling (Refrigerator & Freezer Repair)
by GraceC 11/1/2016 12:11:48 PM(UTC)
Bevearge Fridge not Cooling (Refrigerator & Freezer Repair)
by abenb 9/10/2016 3:37:47 PM(UTC)
