My ice maker solenoid has been making a "chattering" noise when filling the tray and the water coming from the fill tube just sputters out. I have replaced the solenoid assembly with a new one and the chattering continues. If I use the wire jumper on the ice maker (L&V), the solenoid pumps water to the ice tray quietly and is a solid stream as it should be. Could this be a problem with the ice maker?
Thank you
A model number would be helpful. Find your model number - AppliancePartsPros.comPerhaps try measuring the voltage across the valve. Should be 120 volts, at least the ones I have seen are 120 volts. if low you may have a bad connection somewhere or a bad control board. May even be a problem with the ice maker some of them control the valve directly. |
THIS FORUM IS DEAD!!!!!!! |
