ranand
#1 Posted : Friday, July 10, 2015 11:33:55 AM(UTC)
ranand
This is a 2005 KUDI02IRBS1. The unit like the user home2sale had a leaking gasket which was replaced in 04/15 and hose with drain flapper valve 05/15. Unit on 05/07/15 was running and there was a strong smell of what can be described as burning plastic. Also accompanied by a sound. Drained DW and then removed kickplate checked to see if there was any scorching underneath. Nothing visible. Smell seemed to be coming from top right, but control board appears intact and bimetal fuse has continuity.
Checked the heater on wednesday using Commerical Electric multimeter, zeroed, set to x10 (lowest setting) for resistance and heater measures 0 ohms. Replaced with a new one and a new thermostat to save time but the heated dry does not work still.
Will retest heater, but the two connectors are so far back I need to remove the machine each time which is a pain. Any tips to test this. Also how from the control panel can I test this? I cannot find a schematic for the KUDI series. If the heater has resistance then would the board have failed. Cost of the board is 1/4 a new unit and the parts so far are 41% of a new unit if it is the board, is the 10 year old DW on its last legs?
ranand
#2 Posted : Saturday, July 11, 2015 11:07:29 AM(UTC)
ranand
Think the problem was related to the chopper getting jammed with the dishwasher basket fragment! The chopper must have then caused a current spike and P2 on the control board burnt. The diagnostics never reported a problem.
The P2 must run the chopper and the heater. It overloaded and there is no fuse on P2 so it just overheated. It might be why these panels catch fire.
