mvas
#1 Posted : Saturday, July 4, 2015 4:01:40 AM(UTC)
mvas
I had an evaporator freeze over problem. The Defrost Heater tested OK. The Defrost Thermostat tested OK. The Defrost Thermistor tested OK. When I performed a manual Defrost via Diagnostics, there was 0 volts on the Defrost Pin on the Motherboard. Maybe, a bad relay on motherboard? So, I installed a new WR55X10942 Motherboard in the GE PSI23MGMA BB side-by-side fridge. Using the diagnostics, the Defrost Heater does now energize properly. So, the Defrost heater issue appears to be solved.
Issue #1:
Now when I test the Thermistors via the Diagnostics, the test results are different ...
With the Original motherboard (EBX1005G01 REV L) ...
Thermistor #1 - Fresh Food Top = PASS
Thermistor #2 - Fresh Food Bottom = PASS
Thermistor #3 - Quick Chill = FAIL
Thermistor #4 - Evaporator = PASS
Thermistor #5 - Freezer = PASS
Thermsistor #3 should fail because this model does not have Quick Chill.
With the NEW motherboard (WR55X10942) ...
Thermistor #3 - Quick Chill = PASS
Thermistor #5 - Freezer = FAIL
I do not understand why Thermistor #3 is now PASS
and Thermistor #5 is now FAIL.
Did the order of the Thermsistors in the Diagnostic Test change?
Issue #2:
The Evaporator Fan would STOP when either door was opened.
The Evaporator Fan continues to RUN when either door is opened.
Did this functionality change ?
Is there a list of the CHANGES in the WR55X10942 motherboard?
NOTE: I did NOT clip wire from Pin #2 of J-1 because this is a Side-by-Side (not bottom freezer) and Serial Number begins with "GA" (not in list).
Thank You
