coastalhousewife
#1 Posted : 10 years ago
coastalhousewife
I have a top loading Maytag washer - the model is A408, though I'm not sure how helpful that information is (since I called Maytag today and they told me the serial number I gave them was 2000 but the model number was "invalid").
Basically, I noticed not too long ago that sometimes I would set up a load for washing, the washer would fill with water, but instead of progressing to agitating, it would start making a buzzing noise and do nothing. Once I left the washer running because I assumed it was working (had our very loud dryer running right next to it and didn't hear the buzzing sound upstairs) - I came back to a washer that said "off" but was still full of soapy water and unwashed clothes. For the first few times I noticed this, I would turn the washer off by setting the dial to "off" and then come back in an hour and try again. Usually that worked...not the problem has progressed to the point where nothing works and the washer simply will not agitate, rinse, spin or drain.
Repair companies recommended by Maytag were extremely shady and evasive about how much it would cost to repair. I'd much rather we repair it ourselves if it's an easy to intermediate fix...otherwise we have to ask our landlord to replace it, which I don't really want to do.
Any ideas what would cause this? Experience with repairing the problem?
I'd be very thankful for any advice!
sidfink43
#2 Posted : 10 years ago
sidfink43
Your choices here are
1. broken belt - not likely since you could make it work by resetting
2. bad motor
3. bad transmission
4. bad timer.
You can check the belt by taking off the front panel. If that is not the problem then given the age of the machine (its really old) I don't think fixing it is a good option.
Not sure I understand why you don't want to ask the landlord to replace it. If the washer is included in the lease then he or she owes you a working washer, and this one have lived much longer than its life expectancy. If the landlord does not want to spring for a new one, a used Whirlpool top loader in good condition with no electronics is a nice option.
