sassylady1
#1 Posted : Thursday, June 18, 2015 7:44:05 PM(UTC)
sassylady1
This gas wall oven by Frigidaire was made in 1993. Recently the beeper started going off every hour or so. How do I stop it from continually going off.
I've looked online for a User Manual and learned that it has been discontinued.
Simon / APP Team
#2 Posted : Friday, June 19, 2015 1:14:24 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unplug the range, take off the rear cover of the control panel. Locate at the back of the clock assembly the disc 2" or little less in diameter with two wire going to it. Use a side cutters to cut any of this two wires. It should take care of the beeping!
Part number: AP2585003
Thank you.
Simon.
sassylady1
#3 Posted : Sunday, June 21, 2015 6:55:32 AM(UTC)
sassylady1
To
Simon / APP Team
Since you did not acknowledge the title.
The title of this thread is GAS WALL OVEN, it never said
anything about RANGE.
I am looking for answers to my question about a GAS WALL OVEN!!
How do I stop it from beeping.
Simon / APP Team
#4 Posted : Monday, June 22, 2015 8:34:23 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Sorry for calling your oven a range. But the instructions are basically the same - you need to turn the power to the oven off, open the control panel and cut one of the wires that goes to the large disc at the clock assembly. I provided you with a picture of the clock and if you click on it and then click on the rear view of the clock, you will be able to understand what to do.
Thank you.
Simon.
Maytag CWG3600AAB Gas Wall Oven (Oven Repair (including Ranges and Cooktops))
by bdgabriel1 2/28/2022 7:07:47 AM(UTC)
JENN-AIR MODEL JGM8130DDM SLIDE IN GAS WALL OVEN (Oven Repair (including Ranges and Cooktops))
by Guest 11/21/2021 5:35:44 PM(UTC)
Whirlpool SB130PER4 Gas Wall oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by sikhnerd 10/17/2012 10:00:32 AM(UTC)
Frigidaire gas wall oven- burner won't stay lit (Oven Repair (including Ranges and Cooktops))
by tkeller 7/19/2011 9:39:58 AM(UTC)
Ignitor for Tappan Gas Wall Oven (Oven Repair (including Ranges and Cooktops))
by tommurray 1/14/2011 10:31:58 PM(UTC)
tappan gas wall oven (Oven Repair (including Ranges and Cooktops))
by lneil216@yahoo.com 10/25/2010 2:16:11 PM(UTC)
MAYTAG Gas Wall Oven CONTROLS DOESNT WORKS (Oven Repair (including Ranges and Cooktops))
by luthien 9/27/2010 12:41:24 PM(UTC)
Gas Wall Oven SB160PEXQ1 wont Ignite! (Oven Repair (including Ranges and Cooktops))
by smckeone 4/21/2010 3:36:06 PM(UTC)
Maytag Gas Wall Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by jpecobird1 6/30/2009 5:29:13 AM(UTC)
1982 Gas Wall oven will not heat (Oven Repair (including Ranges and Cooktops))
by trikerdave 4/21/2009 2:14:41 PM(UTC)
Gas wall oven (Oven Repair (including Ranges and Cooktops))
by dlb 1/6/2009 9:38:18 PM(UTC)
Jenn Air gas wall oven won't ignite (Oven Repair (including Ranges and Cooktops))
by tamcasey 11/12/2008 8:32:44 PM(UTC)
Gas wall oven will not light (Oven Repair (including Ranges and Cooktops))
by Marrel 6/12/2008 12:13:15 PM(UTC)
