atticus1
#1 Posted : Thursday, June 11, 2015 5:28:24 PM(UTC)
atticus1
My Ice maker is not making any Ice does any body have any suggestions, it is a MayTag Refg double door with the freezer on the bottom.
Jeff / APP Team
#2 Posted : Friday, June 12, 2015 7:17:10 AM(UTC)
Jeff / APP Team
Make sure the freezer is between 0° and 5°. You need to check and see if there is power going to the water valve when the icemaker cycles. If so, replace the water valve on the unit. If not, or the icemaker does not cycle, you will need to replace the icemaker on the unit. Also, check and make sure the fill tube on the unit is not frozen and clogged. If so, replace the water valve and thaw out the fill tube. You can test this with a multi-meter. Here is a link on how to use a multi-meter. http://forum.appliancepartspros...continuity-ohmmeter.html
Part number: AP3873826
Whirlpool Gold Refrigerator ice maker not making ice. (Refrigerator & Freezer Repair)
by jcochran43 8/12/2009 8:50:01 AM(UTC)
Thermador Ice maker not making ice. (Refrigerator & Freezer Repair)
by nmeadows722 6/14/2009 10:26:13 AM(UTC)
Whirlpool Side by Side Ice maker not making ice. (Refrigerator & Freezer Repair)
by robert72 2/3/2008 11:05:59 AM(UTC)
