heberle1
#1 Posted : Sunday, June 7, 2015 5:45:57 PM(UTC)
heberle1
Washer runs, agitates but will not go into drain mode and pump out water.
sidfink43
#2 Posted : Sunday, June 7, 2015 5:51:31 PM(UTC)
sidfink43
Check your lid switch, this sounds like a classic lid switch problem. If you want confirmation open up the console and use a jumper wire to bypass the switch. If it works that confirms that the lid switch needs replacing.
heberle1
#3 Posted : Sunday, June 7, 2015 6:06:05 PM(UTC)
heberle1
My washer runs, agitates but will not start to pump out the water. Is the motor that drives the washer the same for the pump?
fairbank56
#4 Posted : Sunday, June 7, 2015 6:23:53 PM(UTC)
fairbank56
Groups: Expert
Yes, take the advice given. Washer will still fill and agitate with a faulty lid switch but will not drain or spin.
Eric
