smev123
#1 Posted : Sunday, June 7, 2015 7:30:40 AM(UTC)
smev123
Whirlpool washer stops after wash cycle, before draining to rinse.
Open lid, close lid. Starts right back up and finishes complete wash as normal.
Took a good bit of fiddling around to determine the simplicity of the work-around.
First occurrence Thursday. Repeated twice over the weekend. Exact same each time once I figured out the lid dance. No knob on-off, no trying different wash cycles, nothing....just the lid.
Assuming that it's something with the timer. Please confirm.
Smev123
SE Michigan
fairbank56
#2 Posted : Sunday, June 7, 2015 11:37:51 AM(UTC)
fairbank56
Groups: Expert
Assume that's an LSR8133 not LSB. Open the control panel and jump out the lid switch connection. If problem goes away, replace the lid switch. These switches are prone to coming apart.
Lid switch bypass: https://www.youtube.com/watch?v=XAnQ6Ovvnuc
Whirlpool 3949247 Lid Switch Assembly - AppliancePartsPros.com
Eric
smev123
#3 Posted : Sunday, June 7, 2015 5:58:04 PM(UTC)
smev123
Now it won't repeat the problem.
When it does, i'll try the bypass.
Hope it's the switch. They're cheaper!
Guest (4)
