herkyfred
#1 Posted : Sunday, May 17, 2009 11:32:57 PM(UTC)
herkyfred
the gears for both the "load size" and "method" (whites, casuals, etc.) do not function properly. The 'water temp" dial works fine. I am assuming that this is one unit for all 3 dials. The "load size" dial is dead and will not go to any other options besides "large". The "method" dial seems to not only have options with turning the dial (have to force it around), but the timing mechanism seems off based upon times to do loads on various settings versus "normal time".
#2 Posted : Monday, May 18, 2009 4:11:37 PM(UTC)
This is a duplicated thread.
Answered here: http://forum.appliancepartspros...3917-washer-problem.html and here:http://forum.appliancepartspros...16-re-dryer-problem.html by [COLOR="Red"]richappy[/COLOR] and [COLOR="Red"]denman[/COLOR].
