SPassmore
#1 Posted : Tuesday, May 19, 2015 11:28:27 AM(UTC)
SPassmore
we were getting an ocasional runaway element error messages (and burnt food), but they were far apart. and turning the oven off from the control panel worked. Now, the element turns on conatantly unless i disconnect power. The temp sensor seems to accurate temp (and resistence when mesured hot and cold), the heating element (broiler element in lower oven) heats up red hot along the entire element. I see no evidence of shorting.
#2 Posted : Wednesday, May 20, 2015 2:27:58 AM(UTC)
I cannot find any info on the given model number.
Please check it.
Sounds like a control board problem.
SPassmore
#3 Posted : Wednesday, May 20, 2015 7:08:12 AM(UTC)
SPassmore
Mer6771aab
#4 Posted : Thursday, May 21, 2015 1:07:04 AM(UTC)
Parts for Maytag MER6771AAB Range - AppliancePartsPros.com
Here is a manual
http://appliancejunk.com...wnloads;sa=view;down=390
You will have to join the site and be logged in to be able to download it.
Still looks like a control board problem re: the lower oven broil relay is always closed.
Could be the electronics on the board holding it closed or that the relay's contacts are welded together.
