nascar_madman
#1 Posted : Sunday, May 17, 2009 4:54:17 PM(UTC)
nascar_madman
My Amana side by side refrigerator quit cooling and freezing. All items in the freezer were thawed out. I saw that the coils under the refrigerator were plugged with lint and dirt so I blew them out with compressed air. I left the unit off for about 3 hours (unplugged). When you plug it in the fan runs and the compressor makes a rattling noise for about 5 seconds then stops. The fan continues to run. It will cycle through attempting to run every few minutes. The model numbers listed inside the door are SQD26VW 24.7 cu ft.
Thank you
Dan
woodchuckie
#2 Posted : Sunday, May 17, 2009 6:09:56 PM(UTC)
woodchuckie
Check the starter/overload relay. here- Refrigerator Repair Guide: How To Test the Compressor Relay - ACME HOW TO.com
If that's not the problem it's probably the compressor.
nascar_madman
#3 Posted : Sunday, May 17, 2009 7:53:26 PM(UTC)
nascar_madman
When the refrigerator tries to run it trips out after a few seconds. If you unplug it after that happens you wait a few moments and you will hear a click. It will then try to run again. It then trips out after a few seconds. What would you suggest?
woodchuckie
#4 Posted : Monday, May 18, 2009 4:03:36 AM(UTC)
woodchuckie
See my previous post.
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
Frigidaire refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by mrsmobley 6/10/2013 7:37:50 PM(UTC)
by carmonafam 3/31/2013 11:12:19 PM(UTC)
Frigidaire Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by cca610 11/5/2012 2:01:36 PM(UTC)
GE Profile Arctica Refrigerator Not Cooling or Freezing But Running (Refrigerator & Freezer Repair)
by mGalicia 5/29/2012 3:15:30 AM(UTC)
Maytag Plus Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by mangman 5/12/2011 7:04:56 PM(UTC)
Maytag Refrigerator not cooling or freezing, makes buzzing on start up. (Refrigerator & Freezer Repair)
by ghartman21 12/31/2010 3:00:55 PM(UTC)
refrigerator not cooling or freezing properly. (Refrigerator & Freezer Repair)
by Bill K 4/3/2008 1:12:15 PM(UTC)
by diaz1023 10/19/2007 11:22:15 PM(UTC)
