mkanet
#1 Posted : Friday, May 15, 2015 12:12:19 PM(UTC)
mkanet
Our Whirlpool Ultimate Care II washing machine started making a very loud noise during a load today. The water will drain, however it won't spin or agitate. I did some troubleshooting and it looks like the coupling is good. I am able to rotate it both directions and all plastic appears to be intact, although I didn't take it apart. From other reading online it sounds like it could be the clutch, although I don't want to blindly replace parts without knowing for sure. I'm including a dropbox file link to an audio file of the noise it makes, hoping that will help narrow down the issue.
https://www.dropbox.com/s/canx3a...ydd/WasherNoise.m4a?dl=0
Thanks,
Mike
fairbank56
#2 Posted : Friday, May 15, 2015 4:39:09 PM(UTC)
fairbank56
Groups: Expert
It's not the clutch because the clutch has no function during agitation. It's most likely a faulty coupler. I would pull the motor and check it out.
Eric
mkanet
#3 Posted : Tuesday, May 19, 2015 11:31:54 AM(UTC)
mkanet
It looks like you might be right. The part that connects to the motor was cracked. I'm ordering the replacement part now. Thanks!
